Brave on iOS 27 keeps freezing when autofilling passwords and 2FA codes with Proton Pass
I’ve been having a really frustrating issue with Brave on iOS 27 since the initial 27.0 release, and it’s still not fixed.
Every time I try to autofill a password using Proton Pass, Brave freezes and doesn’t respond immediately. If I wait a bit, the password eventually gets filled in, but Brave itself remains completely frozen. I can’t scroll up or down, open settings, or interact with anything in the browser.
Autofilling 2FA codes from Proton Pass is even worse. Most of the time, Brave freezes completely and becomes unusable until I force-close the app and reopen it.
This has been happening consistently since iOS 27.0 was first released, and it’s extremely annoying having to restart Brave just to log in to a website.
Steps to reproduce:
  1. Open Brave on iOS 27.
  2. Go to any website that requires a login.
  3. Try to autofill a username or password using Proton Pass.
  4. Brave freezes, and even if the password eventually gets filled in, the browser remains unresponsive.
  5. Try autofilling a 2FA code from Proton Pass.
  6. Brave freezes completely, often requiring me to force-close and restart the app.
Important things to note:
  • This issue started with the initial iOS 27.0 release and is still happening.
  • Password autofilling causes Brave to freeze, but 2FA code autofilling is significantly worse.
  • Proton Pass works perfectly fine in other apps.
  • I have absolutely no issues autofilling passwords or 2FA codes in Safari or Startpage Browser on the same iPhone, using Proton Pass.
  • This only happens in Brave, which makes me believe it’s an issue with how Brave handles autofilling on iOS 27.
  • The issue is not limited to one website. It happens across different websites when using Proton Pass.
Software versions:
  • iOS: 27.0.1
  • Brave for iOS: 1.97 (60)
  • Proton Pass for iOS: 1.22.1
I don’t understand why this is happening only in Brave when the exact same autofill process works without any issues in Safari, Startpage Browser, and other apps on the same device.
This is a pretty serious issue considering that autofilling passwords and 2FA codes is something people use multiple times a day. Having the entire browser freeze every time I try to log in is ridiculous.
Can someone from the Brave team please look into this and acknowledge the issue? Is this a known bug, and is there a fix being worked on?
It’s been happening since the initial iOS 27.0 release, and multiple updates later, nothing has changed.
I really like Brave and would prefer to keep using it, but I’m seriously considering switching to another browser if this isn’t fixed soon. Having to constantly force-close and restart Brave just to autofill a password or 2FA code is not acceptable, especially when every other browser I’ve tried works perfectly fine.
I also found other users reporting very similar issues with Proton Pass on iOS 27, particularly when autofilling passwords and TOTP/2FA codes.
https://www.reddit.com/r/ProtonPass/comments/1win63e/totp_autofill_crashes_app_ios27/
https://github.com/brave/brave-browser/issues/52907
Some users describe significant autofill delays, apps freezing or becoming unresponsive, and having to force-close apps. This sounds extremely similar to what I’m experiencing in Brave.
Brave also has an open GitHub issue for improving autofill on iOS:
https://github.com/brave/brave-browser/issues/52208
Hopefully this additional information helps the Brave team investigate.
@bladerunnertoast
May interest:
‘Can't find out how to use Proton Pass in Brave IOS - #3 by Welshelvis’
Thanks for the reply. I don’t believe that is the issue I’m describing.
Proton Pass is already configured correctly as my default password manager, and autofilling works perfectly fine in Safari, Startpage Browser, and other apps.
The problem is specifically with Brave on iOS 27. When I attempt to autofill a password using Proton Pass, Brave freezes and becomes completely unresponsive. Sometimes the password eventually fills in after a delay, but the browser itself remains frozen.
Unless I am misunderstanding, my issue is not setting up Proton Pass or getting autofill to work. Its the freezes/crashes that come with using it.
@bladerunnertoast
Re the following, I use such testing for browsers on iOS > Brave Browser (iOS) and Safari (iOS). You probably can also, for other iOS browsers. Compare what you see in the Web Inspector > Network window per browser.
So, again, another may interest … according to Brave Search (Answer with AI):
To view the iOS Safari Web Inspector (developer tools) > Network window using MacOS Safari Web Inspector (developer tools), you must enable remote debugging and connect your iPhone to your Mac.
1. Enable Web Inspector on iPhone
On your iPhone, go to Settings > Safari > Advanced and toggle Web Inspector to ON.
2. Enable Develop Menu on Mac
On your Mac, open Safari > Settings > Advanced and check Show features for web developers (or “Show Develop menu in menu bar” on older macOS versions).
3. Connect and Trust
Connect your iPhone to your Mac via USB cable. If prompted, tap Trust on your iPhone.
4. Open the Network Tab
  • On your Mac, open Safari > Develop and select your iPhone from the list.
  • Select the specific web page you want to debug from the submenu.
  • The Web Inspector window will open. Click the Network tab to view network requests, timing, and resource details.
Note on Wi-Fi: While some sources mention connecting via network, the standard and most reliable method requires a USB connection. If you wish to use Wi-Fi, ensure both devices are on the same network, pair them via Settings > General > Remote Devices on the iPhone, and select Use for Development in the Mac’s Develop menu before disconnecting the cable.
(AI-generated answer. Please verify critical facts.)
I have used the procedure, to discover.
I connected iPhone to Mac via cable.
Study how to use Brave Shields:
What does any of this have to do with the actual issue? This is the 2nd time you do that in this thread.
Why are you sending someone on a whole Web Inspector/network debugging side quest instead of addressing the likely autofill-specific bug? And the unrelated Brave Shields explanation at the end makes this even more confusing.
Do you reply to every post with AI slop generic troubleshooting dump, even if its unrelated to the problem?
@bladerunnertoast
Proton Pass needs network connectivity for account authentication, synchronisation, and certain remote features.
There may be a particular networked activity/transaction that hit a snag or is the snag.
Some time ago, your password filling issue was caused by a bank’s website constantly retesting for satisfaction of a WebGL fingerprint. Without the particular fingerprint, filling the password field would seem to not accomplish anything.
The website never got it; the browser never actually sent it. “Nothing happening” can sometimes be seen in the DevTools window.
@Evan123 My guy, get these bots out of here.
As per Proton:
Our team has recently noticed an issue with iOS 27 in Proton Pass, particularly when using the Proton Pass auto-fill feature.
When auto-fill is triggered, Proton Pass will freeze and fail to auto-fill the selected item.
At the moment, the workaround is to put the app in the background and reopen it, or open the Notification Center and then close it.
Although this appears to be a regression in iOS 27 for third party password manager app, our team is still investigating whether there is a fix or additional workaround that we can provide from our side to address the issue.
