Description of the issue: I can no longer see torrents listed in qbittorrent web. This is a new issue for me since i’ve been using Brave a long time and not run into this problem before. I have updated to a newer version of qbittorrent web docker container and that could have something to do with it affecting Brave in a new way. Or it could be a Brave update. Either way, this is a big problem for me as I use qBit often. I did find qbittorrent works fine in chrome, however.
Exact URL of the website in question: personal ip, cannot post it here
Did the issue present with default Shields settings? (yes/no) yes
Does the site function as expected when Shields are turned off? no
Is there a specific Shields configuration that causes the site to break? If so, tell us that configuration. (yes/no): No. Setting changes do not fix the issue.
Does the site work as expected when using Chrome? Yes
Brave version (check About Brave): 1.78.102
