When I was developing with ThreeJS and PixiJS the WebGL simply does not turn on. I had to go to Chrome to see if it was the browser’s fault. Hope you guys fix this or if I’m doing something wrong, please tell me. Thanks
May be blocked by fingerprinting via shields. Try disabling and check it should work
Going through https://threejs.org/examples/ and https://pixijs.io/examples/ both seem to render okay, at least with sheilds on
