On macOS Tahoe 26.2, Brave causes severe battery drain and sustained high CPU/GPU usage on a MacBook Pro M3. The Brave Browser Helper (GPU) process consistently runs at extremely high CPU and GPU utilization (often ~75–80%+) during normal browsing, leading to rapid battery drain and system heat.
This occurs even without external displays and without heavy workloads such as gaming or continuous video playback.
- Install Brave version 1.85.120 on macOS Tahoe 26.2
- Launch Brave and browse normally with multiple tabs open
- Observe Activity Monitor after several minutes
- Brave Browser Helper (GPU) shows sustained high CPU and GPU usage
- Battery drains rapidly while Brave is running
Brave should maintain low CPU and GPU usage during normal browsing and idle states, comparable to Safari, without excessive battery drain or sustained GPU utilization.
1.85.120
- macOS: macOS Tahoe 26.2
- Hardware: MacBook Pro M3
- External displays: No
- Hardware acceleration disabled: No (disabling hardware acceleration made overall system behavior worse and more unstable)
- Issue occurs during normal browsing, not limited to video playback
- Activity Monitor shows Brave Browser Helper (GPU) consuming ~75–80% GPU with long sustained GPU time
- Kernel_task and WindowServer usage also increase while Brave is running
