Brave is slow and it freezes and crashes on Samsung Galaxy A5 2015
Your device seems to be quite long, especially considering that android phones usually don’t get more than 2 years of OS updates. How are other browsers holding up? Regardless I believe brave isn’t well optimized for a device that old and theres probably not much you can do except to upgrade to a newer device
Hi @Fannste94, do you have Lollipop or Marshmallow OS?
Brave Help Center states…
…although Lollipop is version 5, it could still struggle. Maybe even Marshmallow would sputter, I don’t know.
I’m using version 8 (Oreo), and the performance is stellar… so don’t feel you need to upgrade big to run Brave smoothly
Other browsers are worse, maybe Vivaldi is a little better
I have Android 6.0.1
It could be that it’s close to the base version, but I’m not sure. I just know that with my 8, Brave performs really nicely. Maybe doing a good clean of your mobile might help its efficiency? Check what background apps you having running, etc? Do you tend to use (a lot of) extensions? Run multiple browsers?..
I tried clearing the app data and I also have a system cleaner and it’s the same, the loading bar shows that the page is loaded but the content is still loading
Maybe this could offer some tips?
Are you at this version?
Edit: This may be more helpful than the last, sorry,
I already tried resetting the router and my phone a couple of times it’s not an issue with them, I tried Brave on another Samsung Galaxy 2019 phone with Android 10 and it’s the same, the bar shows that the page is loaded but the content (images and videos) are still loading, you can try testing Opera and Vivaldi to see how they work
Is this sluggish loading with every site, or only some?
I ask because maybe it’s your Shield settings?
Especially if fingerprinting is set to strict for many/ all sites…
…or you have other strict settings in the Shield…?
Every site and it happens even with the Shield disabled
I see.
I think Support or someone more knowledgable with Android than I will join in on this discssion to further assist you @Fannste94.
I don’t think you having version 6 is the problem, but I really don’t know because you’ve no issues running Vivaldi and Opera…
I’m curious to know what could be the reason for your issue. Hopefully we won’t have to wait too long
Yes i have also the same problem
Yes i have the same problem stuck on search bar
I tried clearing the app data and I also have a system cleaner and it’s the same, the loading bar shows that the page is loaded but the content is still loading very annoying issue
GPU log.txt (4.0 KB)
Optimize the browser for this phone
Device Info 3.1.3
Date Created 2021-05-21 07:04:32
Device
Device Name : Galaxy A5
Model : SM-A500FU
Manufacturer : samsung
Device : a5ulte
Board : MSM8916
Hardware : qcom
Brand : samsung
Build Fingerprint : samsung/a5ultexx/a5ulte:6.0.1/MMB29M/A500FUXXU1CRH1:user/release-keys
USB Host : Not Supported
System
Android Version : 6.0.1
Version Name : Marshmallow
Released Date : October 05, 2015
Code Name : Marshmallow
API Level : 23
Security Patch Level : 2017-08-01
Bootloader : A500FUXXU1CRH1
Build Number : MMB29M.A500FUXXU1CRH1
Baseband : A500FUXXU1CRF1
Java VM : 2.1.0
Kernel : 3.10.49-14143416
Language : English (en_US)
OpenGL ES : 3.0
Root Access : No
Root Management Apps : No Apps Detected
SELinux : Enforcing
Google Play Services : 21.18.15 (040306-373409449)
Vulkan : Not Supported
Treble : Not Supported
Seamless Updates : Not Supported
CPU
SoC : Qualcomm Snapdragon 410 (28 nm)
4 x Cortex-A53 (1.2 GHz)
Processor : ARMv7 Processor rev 0 (v7l)
CPU Architecture : 4 x 1.19 GHz
Supported ABIs : armeabi-v7a, armeabi
CPU Hardware : Qualcomm Technologies, Inc MSM8916
CPU Type : 32 Bit
CPU Governor : interactive
Cores : 4
CPU Frequency : 200 MHz - 1190 MHz
GPU Renderer : Adreno ™ 306
GPU Vendor : Qualcomm
GPU Version : OpenGL ES 3.0 V@140.0 AU@ (GIT@Ia10634f51b)
Battery
Health : Good
Level : 51%
Status : Discharging
Power Source : Battery
Technology : Li-ion
Temperature : 33 ℃
Voltage : 3667 mV
Network
Type : Wi-Fi
IP Address : 192.168.1.101
Gateway : 192.168.1.1
Subnet Mask : 255.255.255.0
DNS1 : 203.0.113.2
DNS2 : 203.0.113.3
Lease Duration : 7 Seconds
Interface : tun0
Link Speed : 72 Mbps
Frequency : 2437 MHz
Display
Resolution : 720 x 1280 Pixels
Density : 320 dpi (XHDPI)
Font Scale : 1.0
Physical Size : 4.97 inches
Refresh Rate : 60.0 Hz,
HDR : Unknown
HDR Capabilities : Unknown
Brightness Level : 7%
Brightness Mode : Adaptive
Screen Timeout : 600 Seconds
Orientation : Portrait
Memory
Random Access Memory
Type : LPDDR3 533 MHz
Total : 1892.0MB
Available : 476.0MB
Used : 1427.0MB
Used Percentage : 74%
System Storage
Total : 2.31GB
Available : 0.11GB
Used : 2.20GB
Used Percentage : 95%
Internal Storage
Total : 11.54GB
Available : 1.48GB
Used : 10.06GB
Used Percentage : 87%
External Storage
Total : 14.45GB
Available : 14.25GB
Used : 0.20GB
Used Percentage : 1%
Camera
Camera - 0
Position : Back
Mega Pixels : 12.8 MP
Resolution : 4128x3096
Focal Length : 3.69mm
Camera - 1
Position : Front
Mega Pixels : 5.0 MP
Resolution : 2576x1932
Focal Length : 1.92mm
Thermal
tsens_tz_sensor0 - 58 ℃
tsens_tz_sensor1 - 57 ℃
tsens_tz_sensor2 - 54 ℃
tsens_tz_sensor4 - 60 ℃
tsens_tz_sensor5 - 59 ℃
pm8916_tz - 52.8 ℃
pa_therm0 - 37 ℃
rt5033-fuelgauge - 33.6 ℃
battery - 33.6 ℃
Sensors
BMC150 Acceleration Sensor
Vendor : Bosch Sensortec
Type : ACCELEROMETER
Power : 0.13mA
BMC150 Magnetic Sensor
Type : MAGNETIC FIELD
Power : 6.0mA
BOSCH Uncalibrated Magnetic Sensor
Type : MAGNETIC FIELD UNCALIBRATED
Power : 6.0mA
TAOS TMD3782 Prox Sensor
Vendor : AMS , Inc.
Type : PROXIMITY
Power : 0.75mA
TAOS TMD3782 Light Sensor
Vendor : AMS , Inc.
Type : LIGHT
Power : 0.75mA
Screen Orientation Sensor
Vendor : Samsung Electronics
Type : PRIVATE SENSOR
Power : 0.13mA
Samsung Geomagnetic Rotation Vector Sensor
Vendor : Samsung Electronics.
Type : GEOMAGNETIC ROTATION VECTOR
Power : 6.13mA
Orientation Sensor
Type : ORIENTATION
Power : 6.13mA
Apps
9GAG
com.ninegag.android.app
Version : 6.104.02r23913-bb3d5863f2
AirAttack 2
com.ArtInGames.AirAttack2f
Version : 1.4.2
Antivirus Free
com.bitdefender.antivirus
Version : 3.133.939
Authenticator
com.blizzard.bma
Version : 2.5.0.14
Authenticator
com.azure.authenticator
Version : 6.2105.3004
Authy
com.authy.authy
Version : 24.3.8
Autodesk SketchBook
com.adsk.sketchbook
Version : 5.2.3
Background Eraser
com.handycloset.android.eraser
Version : 2.7.1
Blokada
org.blokada.fyra
Version : 4.11.1
Bounce
com.genico.bounce
Version : 1.1.4
Brave
com.brave.browser
Version : 1.24.85
Chess
com.jetstartgames.chess
Version : 2.7.7
Device Info
com.ytheekshana.deviceinfo
Version : 3.1.3
Discord
com.discord
Version : 73.12
Downloader for Instagram
instasaver.instagram.video.downloader.photo
Version : 1.25.2
Downloader for TikTok
com.downloaderfor.tiktok
Version : 1.77
Google Play services for Instant Apps
com.google.android.instantapps.supervisor
Version : 6.14-release-367282920
Headset Notifier
org.nocrew.tomas.headsetnotifier
Version : 1.1.0
Instagram
com.instagram.android
Version : 188.0.0.35.124
LED Blinker Lite
com.ledblinker
Version : 8.1.3-lite
LightSaber
com.pombingsoft.lightsaber
Version : 3.1
Lite
com.facebook.lite
Version : 251.0.0.4.119
Ludo Club
com.moonfrog.ludo.club
Version : 2.1.5
Meme Generator Free
com.zombodroid.MemeGenerator
Version : 4.6050
Messenger Lite
com.facebook.mlite
Version : 139.0.0.3.118
Microsoft SwiftKey Keyboard
com.touchtype.swiftkey
Version : 7.7.9.3
Moj Telenor
rs.telenor.mymenu
Version : 1.24
Moja mBanka
rs.Raiffeisen.mobile
Version : 18.0.2
Neuralyzer
com.thunkable.android.kechkoindustries.neuralyzer
Version : 2.2
Polish
photo.editor.photoeditor.photoeditorpro
Version : 1.34.88
Radio Uzivo Srbija
net.radioexpert.radio.uzivo
Version : 1.3.6
Shazam
com.shazam.android
Version : 11.25.0-210506
Speedtest
org.zwanoo.android.speedtest
Version : 4.5.36
Start
com.vodafone.smhs
Version : 16.0.1
Steam
com.valvesoftware.android.steam.community
Version : 2.3.12
Streets of Rage
com.sega.streetsofrage.classic
Version : 6.2.0
TikTok
com.zhiliaoapp.musically
Version : 19.5.4
Twilight
com.urbandroid.lux
Version : 12.3
Vanced Manager
com.vanced.manager
Version : 2.6.0 (Crimson)
Vanced microG
com.mgoogle.android.gms
Version : 0.2.18.210500
Viber
com.viber.voip
Version : 15.3.0.2
Wallpaper Changer
de.j4velin.wallpaperChanger
Version : 4.8.15
Weather
ru.yandex.weatherplugin
Version : 11.25
XRecorder
videoeditor.videorecorder.screenrecorder
Version : 1.5.0.1
Yandex.Disk
ru.yandex.disk
Version : 4.86.1
YouCut - Video Editor
com.camerasideas.trimmer
Version : 1.454.1121
YouTube Vanced
com.vanced.android.youtube
Version : 16.16.38
