Brave for MacOS won't launch in fullscreen mode
Description of the issue: Brave for MacOS does not remember the last used screen mode.
  1. Launch Brave from dock
  2. Set Brave to full screen mode using green button
  3. Quit Brave using <command + Q>
  4. Re-launch Brave from dock
Brave launches in full screen mode
Brave Version( check About Brave): v1.90.128
I have used Brave on Windows, Linux, iPadOS & Android, but I’m a MacOS noob :slight_smile:
MacOS Tahoe 26.5.1
Brave behaves differently between the 2 user accounts on my Mac:
My account (admin) - Brave launches in full screen mode if I last used it in that mode.
My wife’s account (standard) - Brave launches in windowed mode even when last used in full screen mode.
In both accounts the “Close windows when quitting an application” setting is disabled.
I have tried promoting my wife’s account to admin with no effect.
I created an Apple ID for my wife’s account (she didn’t have an ID) in case MacOS was saving some Brave settings to the cloud - no effect.
I can force Brave to open full screen by using a script in my wife’s account, but this seems like a kludge - I would rather the app behaved the same in both accounts.
TIA for any help
Rob
I just tested this and the browser launches in the mode it was last viewed in. Is the browser on the same version for both accounts?
Hello & thanks for your reply.
The Brave version is the same for both accounts - I installed Brave from the admin account then later created my wife’s standard account. Brave was already available in her account without having to install again, so I am not surprised that both accounts have the same version.
It should be noted that I am not using any of the Brave sync capabilities for either account and neither has an associated Brave account.
Just as a test, I installed the Helium browser (my daily driver in Windows) and it also failed to remember full screen/windowed setting between quit and re-launch.
Safari seems to be well behaved in this respect, but I will give Firefox a try and report back.
I installed Firefox from the admin account and it does not remember full screen mode from last launch on either account.
Can you check and see if it makes any difference how you enable full screen? For example, try using the green fullscreen/maximize button on the macOS, then closing and reopening. Then try using the browser’s fullscreen button in the main menu.
I tried all methods I know of enabling full screen:
<fn + F>
<ctrl + command + F>
green button
View menu\Enter Full Screen
In all cases Brave fails to remember the full screen setting when re-launched from my wife’s account and behaves as expected from my account.
Note Brave now at v1.91.168
