Problem:
When logging into any website, I have to click on the password field to select my account before signing in.
Desired Solution:
I want the login credentials to be filled in automatically without needing to select the account manually.
Wow
I didn’t notice because I was using Bitwarden.
Sorry if it sounds like an advertisementbut I consider this a recommendation that deserves it Bitwarden is better than the password manager from Google or Brave, in Bitwarden you can add multiple URLs, if the password is used on multiple services, then there will be no confusion, duplication and errors of the same passwords, there is a lot more in it
If it’s on one, it’s the site’s fault, the fields are configured incorrectly, and if it’s on all of them, then it’s definitely something more
@BlackPes1 can you confirm whether or not this occurs for all sites or just one specific site?
. . . . . . . . . . . . . . . is it safe ?
. . . . . . . . . . . . . . all sites .
Of course.
