Brave does not use the graphics card
- Running linuxmint 22
- Enable gpu and all drivers, set Brave to use graphics acceleration in settings.
- Brave continues to use cpu and fails on graphics intensive sites.
Brave using graphics card
Version 1.78.97 Chromium: 136.0.7103.93 (Official Build) (64-bit)
Does this help from brave://gpu?
Graphics Feature Status
Canvas: Hardware accelerated
Direct Rendering Display Compositor: Disabled
Compositing: Hardware accelerated
Multiple Raster Threads: Enabled
OpenGL: Enabled
Rasterization: Hardware accelerated on all pages
Raw Draw: Disabled
Skia Graphite: Disabled
Video Decode: Hardware accelerated
Video Encode: Software only. Hardware acceleration disabled
Vulkan: Enabled
WebGL: Hardware accelerated
WebGL2: Hardware accelerated
WebGPU: Disabled
WebNN: Disabled
