That was right.
It seems to have worked, and has held between reboots, so hopefully I can call that the answer this time!
Thank you!
That was right.
Thank you!
@thelewiss,
Happy to hear it ā please let me know if the problem resurfaces. Iāll leave this thread open for the time being just in case.
@Mattches - Iām sorry to tell you, Itās come back again. I rebooted and it stopped working again. I havenāt rebooted again to see if thatāll fix it. Itās very intermittent.
Should I be looking at reinstalling my system?
Thank you.
I have a feeling that it is something to do with using Task Scheduler to open the App Windows, as now iāve disabled them from starting with logon, Brave responds normally, and i can open it from taskbar, etc.
And once iāve started them manually, it seems to work fine.
@thelewiss,
To clarify, you mean the scheduler that launches the browser upon logging into your PC?
I have tasks set up like these - WebApp ones in yellow
Example of task:
On further thoughts, having āstop the task if it runs longer thanā¦ā doesnāt seem like a good idea to be enabled, since i do leave my PC on and hibernate it. I will turn those off. Iām only on 9hrs uptime, and I can open Brave properly . This might be my fault!
