Brave does not function in ios enviroment
Hello, I have multiple problems implementing brave into my iphone enviroment. They are simple, but annoying problems.
  1. Unable to save photos - when I long press an image and click “save image”, which normally puts that picture into my gallery, the photo is not added, nothing happens. I can only take a screenshot and cut out the required photo, which is very inconvenient.
  2. Unable to be forwarded into installed app:
    Opening a link that forwards you into an app you have on your iphone only opens Appstore page, but does not open the actual app, rendering all types of invite links, referals etc. completly unusable, all thanks to brave.
I am very surprised I have not been able to find open ticket for neither of these problems.
Thank you
Jan
Version 1.75 (179)
Iphone 14, ios up to date
I long-pressed an image, and no "save image” option (and, no such option when using the share button in the following screenshot - in fact, the options available if using that share button, are very limited):
To save the image, I did not use the long-press.
Instead, I used the share button at the bottom of the iPhone display:
SOMETIMES, the resulting menu shows the “Save image” option:
SOMETIMES, the resulting menu DOES NOT show the “Save image” option:
The Share button menu options change when reloading the webpage.
I consider the menus failures to be a Brave Browser (iOS) menus bug. @Mattches
I am using an iPhone 14 (iOS v17.7.2); BB v1.75 (179)
UPDATE:
I updated iOS to v18.3.1 - Same results.
Test image webpage link:
https://myperfectplants.com/cdn/shop/files/Okamee_3_800x.jpg?v=1702405333
When I managed to get the menu with the “Save image” option, the first time I got that far, I was able to save the image to the iPhone’s Photos collection.
But subsequent attempts resulted in no action when clicking the “Save image” button.
Hey, that is answering a different problem not mentioned in this post. I do see the button to add to photos, but the button doesn’t actually do anything - mainly in google pictures or facebook. Sometimes it saves it to files, not gallery, which is also inconvinient.
@Prastako I’m not able to replicate. I just did Save To Photos and then opened by Photos app and it was there.
The only way I am able to have issues as you say you are is if I remove permissions. Which makes me wonder if you have your settings to block Brave. In your iPhone go to Settings → Apps → Brave and you’ll have a list of things for Allow Brave To Access. One of those is for Photos. You have an option for None or Add Photos Only
If I toggle to None then tapping Add To Photos does nothing. But when allowed to Add Photos Only it works with no issues.
Not having any issue on this either. But would be nice if you could give some specific examples perhaps. Also have to say you need to make sure to check your settings as well,
In Brave if you go to SettingsBrave Shields & Privacy you’ll see a toggle option for Allow universal links to open in external apps. If this isn’t turned on then it’s not going to switch over to other apps and instead is just going to try to open everything in Brave.
NOTE
Make sure you realize in the first one, the settings are your phone’s settings and not Brave’s.
The second one is in Brave, not your phone.
I wonder if this might be part of your issue? Current iOS is 18.3.1. You’re lagging behind quite a bit.
I’m on the same version.
@Saoiray
Tx for suggestion.
