I do get everytime I use Brave problems. When in use it will stop.
Screen goes black. And after a while I get this error message. I have
used it for years with no problems and I think it’s a great browser.
Also I stopped all the extensions but that doesn’t seem to work.
This particular error message with error codes 0xe0434352, 0xc06d007e, 0xc0000417, 0x40000015, 0xc00000d, 0xc06d007f, etc. can appear due to various reasons. For example, you can get it because of a corrupted .NET Framework installation as well as a corrupted device driver. Try our following suggestions:
Use .NET Framework Repair Tool
Run Check Disk
Troubleshoot in Clean Boot State
Run System File Checker
Use System Restore.
And thereafter, the suggested fixes / steps to take at that website.
After all that, then:
How do I manually submit Brave Browser crash reports?
After you click the “Send Now” button, return to brave://crashes and gather up the Crash Report ID numbers that end with a string of zeros. Post the numbers, here, in a new reply. Example of a Crash Report ID number:
