I have an issue with the wifi adapter (Realtek RTL8852BE) that it keeps disconnect the wifi signal time-to-time when watch Youtube Live stream using Brave. I have generated the report for WLAN and the issue points at Error 8003 that the driver disconnecting the connection by itself. The range of disconnection period is very wide, starting from 5 mins to 1 hour-ish which during this range, the connection can be disconnected at anytime. What I can do is only disable the adapter and re-enable it to turn it back on or it won’t come back ever.
I have tried many methods including uninstall the device from Device Manager and install the latest Wifi driver that manufacturer has, change Wifi range from BE to AX, disable the roaming sensitivity, disable the power management to stop the device to save power, etc., none of these working. However, with finally testing the livestream session on FIrefox which do not cause this issue so it turns into conclusion that Brave browser causing the adapter to kill itself for whatever reason, I don’t know.
However the timing of I turned using Brave and Windows forced itself 25H2 on my device is very unclear that when exactly and which comes first. (Due to 25H2 cause a lot of problems on my device lately so I don’t know if this is one of them, or it is Brave itself only)
And as mentioned, the issue starts only when I watch Live stream, doing anything else is fine and no disconnection whatsoever, so what can I do about this?
Open livestream (Youtube/Twitch) on Brave Browser Desktop.
During 5 mins to 120-ish mins the adapter will kill itself eventually.
Expected result: The wifi adapter doesn’t kill itself after watching livestream/do a livestream, can join or perform the session from start to end.
Brave Version( check About Brave): Brave 1.89.143
- Wifi adapter - Realtek RTL8852BE
- Windows 11 – 25H2
