Brave Bug - Need Fix
Chr**e tarayıcısı devredışıyken Brave’de tğm çerezleri ve verileri sıfırladığım zaman tekrar açılmadı, sadece duvar kağıdı görünüyordu. Sorunu çözmek için devredışı bırakılan tarayıcının aktifleştirilip ondan sonra Brave’i yükleyip açmak gerekiyor. Açınca da takılı kalan kısım “Varsayılan Tarayıcı Yap” kısmı diğer Tarayıcı devredışıyken bu pencerenin ortaya çıkmaması.
Translation from Turkish to English (via deepl.com) Description:
When the Chrome browser was disabled, Brave wouldn’t open again after I cleared all cookies and data; only the wallpaper was visible. To resolve the issue, you need to enable the disabled browser, then install and open Brave. When you open it, the stuck part is the “Make Default Browser” section, which doesn’t appear when the other browser is disabled.
@dawgsu , what follows, is my trying to bring your issue to the attention of a member of Brave Support . . .
@Mattches
OP reported that the issue is on an Android phone. Otherwise, both Chrome and Brave Browser are installed.
When Chrome was disabled from being the default browser, then Brave Browser could not be opened to a level of normal operation / satisfaction (OP: “only the wallpaper was visible”).
So, OP then enabled Chrome as default browser; followed by, a re-install of Brave Browser.
Yet, at that point, when running Brave Browser, the OP reports:
(I am not certain whatever switch-throwing action was actually taken, in order to disable Chrome as default browser.)
Hi, this bug occured on Android phone.
@dawgsu can you please tell me what type/model of device you’re using at this time as well as the Android version running on it?
Samsung S24 Ultra Android version 16 OneUI 8.0
Thank you for the information. I apologize but I’m still a little unclear about what the exact issue is. You’re saying that, after un/reinstalling, when you launch Brave it gets stuck during the setup process – is that correct?
Closing/reopening the app doesn’t make any difference?
Yes, even re-installing doesn’t work until i reactivate the default browser that i deactivated before. So the solution is when i reactivate the default browser and than re-install the Brave, problem fixed. So problem about Brave it stuck on the “Do you want to make Brave default browser?” section, silly Brave can’t find any other browser in phone for asking the question :face_savoring_food: .
