Brave bug 47101 - Entra-ID "Device State" not being sent
Description of the issue: Brave does not send device IDs when authenticating with SSO
  1. You need a site that requires authentication with say your company SSO
  2. Log in works fine, but then when redirected to the underlying resource, you get permission denied because the device id is not sent
  3. This is a reported and open issue
Expected result: device id gets sent and you have access to the underlying resource. This behavior has been confirmed working in everything from Chrome, Safari, Firefox, Edge, and Brave seems to be the only macOS desktop browser that does not work, which makes it unusable in these corporate environments.
Brave Version( check About Brave): 1.93.136
Additional Information: Bug already reported here, open for over a year
Thank you for surfacing this. Not sure if this issue is blocked or on hold for some other reason. I’ve added your report to the thread and pinged a couple devs internally to see if anyone can shed some insight on the status of the issue.
Thanks! I can say it’s pretty critical to continuing to allow its use in corporate environments. I know lots of people at $job who have had to stop using it because of this bug. We all hope that’s temporary! :slight_smile:
