"Brave Browser Shutdown unexpectedly Click to restore"
Browser crashes Very often like once in every 10-15mins
This is happening from the last update installed from brave
version mentioned below
i tried creating new profiles but still didn’t stop it from crashing
1 extension being used ‘FDM’
Uploaded Crash Report ID: 72cd0800-38c5-9e0b-0000-000000000000
|Local Crash Context:|35ff2387-9804-424c-9486-9b0e4b8b3a72|
Version:1.63.169
Windows 11 Home SL
can you help me get this fixed
@Rakshith it’s currently late on Friday night. Support isn’t active on weekends or American holidays. So likely going to be a little while before they can check in on you. Other thing I’ll say is it will be helpful for them if you can copy/paste the Uploaded Crash Report ID rather than screenshot. The reason is they can then copy/paste it and there’s no risk of typos. Otherwise they have to eye it down and try to type it out, definitely is a pain.
That said, I can try to walk you through a variety of steps for troubleshooting if you’d like just to try to get you some sort of help over the weekend. Guess just let me know if you want me to provide a list of things you can try. And if so, I’ll want to know everything you have tried.
Did you install on new profile or you tested the profile with no extension and no changes to settings?
I didn’t install the extension in the new profile;
but the problem persists
Thanks for replying
