Brave browser makes my laptop fan make to much noise
Description of the issue: Brave browser makes my laptop fan make to much noise since today May 4th 2026. The laptop is an HP laptop 15-da0xxx from 2018 with no gpu. I have tested it with removing software updates and extensions and not opening the browser for an extended period of time.
Brave Version( Upgraded Chromium to 147.0.7727.137.):
Hello,
Can you please try the following things:
  1. Try a new Brave Browser profile:
  2. Go to brave://settings/system and toggle on/off the following:image
  1. I assume that you use Windows 10/11. On Windows 11, go to Settings>Display>Graphics and add Brave Browser as a new application:
Go to C:\Program Files\BraveSoftware\Brave-Browser\Application to find brave.exe.
Then select Brave to use “Power saving” graphics.
Your options will be different than mine as you don’t have a GPU. But still, ask for Windows to save power when using graphics on Brave.
This video shows you how you can do the same thing, but on Chrome and on Windows 10: https://youtu.be/BJHKPp9qgXg
None of these thing helped.
Something else seemed to have worked, I switched a random toggle that wasn’t in any of the instructions and the fan is quiet with brave browser open.
The problem came back but also when brave browser is closed.
@mjhcbr
For several years, I have been using Macs Fan Control (on both MacOS and Windows OS machines), in order to keep the computers cool. I can monitor “the engine room” as follows - example is the PC setup (on a Mac that has only 1 fan), and notice the column titles in Task Manager:
After about 5 days of not using the “PC side of the Mac,” I will startup on that partition and wait for some time, for the “PC” to setting down, as there may be software updates and Windows OS processes that are determined to run. That is when the Windows OS Task Manager shows a lot of Power and CPU usage.
Over time, the ebb and flow of the fan speed, sometimes “governs” my opening the Macs Fan Control window and the Task Manager, to see what is happening.
@mjhcbr this is likely not a Brave specific issue if it’s happening when Brave is closed. You might try testing running another app or browser after you restart your machine and test to see if the fan kicks on the way it has been even if Brave isn’t opeend at all.
The fan problem seems to have fixed itself, maybe through an update.
