Brave browser is consuming too much memory and battery without opening any tab on it!
Knowing that I have 8 GB of ram.
Open brave browser with 0 tap opened
Go to Task Manager of windows 10
Google chrome is consuming less memory than brave browser!
Version 1.24.84 Chromium: 90.0.4430.93 (Official Build) (64-bit)
Hi there @yasserberrehail , welcome to Community
Could you kindly open up the task manager through Brave and get a look at what component is hogging the resources.
Instructions how:
Menu --> More Tools Task manager , or right-click on the tab strip (not on a tab) and pick Task manager from the context menu.
Best,
Salty
Hi @yasserberrehail , thank you for your patience.
This is a matter that the Brave Support team has brought up to the Dev team and are working to resolve this issue.
As a possible solution…can you try disabling Hardware Acceleration in settings to see if this resolves the issue?
You’ll find this in Settings --> Additional Settings --> System --> Hardware Acceleration
Best,
Salty
Already disabled nothing has changed.
Hi @yasserberrehail , do you have any extensions in your browser?
Yes I have many extension installed.
Thank you for sharing those screenshots. One last thing, could you please expand the Brave tab in your task manager this would help me to provide a clear solution.
Thanks,
Salty
Hi there @yasserberrehail , thanks for your patience.
Can you try disabling all of your extensions? If that solves the problem, the next steps would be to enable each extension one by one, and seeing which one causes the issue.
system
Closed
June 30, 2021, 5:15pm
12
