Brave browser: frequent major slowdowns & tried other browsers work fine
Description of the issue: Brave browser: frequent major slowdowns & tried other browsers work fine
**Steps to Reproduce (add as many as necessary):
  1. using flatpak and non flatpak brave browser on linux mint and there does not seem to be any rhyme or reason for this slow down**
  2. IT slows down REALLY bad at random times where its basically unresponsive for minutes at a time and sometimes less
  3. I tried asking this question to Chatgpt and other AI engines and fed my system information and other details it askd for, and no resolution!
Actual Result (gifs and screenshots are welcome!): no screenshots
Expected result: Its not supposed to be this bad
Reproduces how often: very very often so I uninstalled brave!
latest brave version (uninstalled it!) and linux mint
System:
Kernel: 6.8.0-110-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0 clocksource: tsc
Desktop: MATE v: 1.26.2 wm: marco v: 1.26.2 with: mate-panel tools: mate-screensaver vt: 7 dm:
I tried to past more system info but it sayd “new users cannot insert more than 4 links” likely because the deb packs had links.
Greetings
Thx for reply
I suspect , brave browser started off light weight and useful with noble intentions.
However , over the past three or four years has gotten very bloated and not useful
This kind of bloat happens to many other programs in applications as well that originally start off as lightweight with noble causes.
Now brave has Tons of freezes, bloat and likely obscene profit motive.
Other browsers do not give me this hassle so I switched to using librewolf and falkon for the time being
I may return if these issues are resolved.
What do you suspect is causing these issues?
