Description of the issue: If i choose to use other Autofill as in this situation i use Keeper Password manager. If Brave setting “Autofill using another service” it will prompt “login to the keeper” when pressing password field on any site, but when i press that, it does not do anything. It does not prompt Keeper biometrics or normal login. But if i leave setting “Autofill with Brave” even tho i dont use Brave password manager, it prompts Keeper login correctly when trying to autofill and it works. I have been in talks with Keeper support and they just wanted to leave this as is coz it works even tho it “works” as in the setting is opposite when it works.
Set Autofill using another service and Keeper as the default autofill service in device settings
Try to login to site that Keeper has passwords saved
Expected result: Keeper will prompt “login to the Keeper” but nothing happens from that.
Brave Version( check About Brave): 1.83.120, Chromium 141.0.7390.122
Mobile Device details: Samsung Galaxy S25 One UI 8.0 Android 16 Build/BP2A.250605.031.A3
