Hi everyone,
I’m new with Brave I just installed it yesterday.
I have 2 icons on my desktop; one icon name Brave and the other its name is: work-brave.
What is the difference?
Thanks
@kasydo The one on the top is the normal shortcut. The one entitled Work-Brave is a shortcut you added to your desktop when you created a new profile. The purple circle there is the design logo chosen when creating the profile.
Basically if you click the work one, it will open in that specific profile. It kins of matches like how you see my different profiles here. I’m in Person 1 which has same circle design, but then look lower and I can switch to Solana BAT test profile which has a different icon color.
Ah!!! Just that. It means I can take one off. Thanks
