Bookmarks - Re Ordering
Context: I have folders in the bookmarks bar, and inside those folders there are times that i would drag and re-order the bookmarks, my issue is that every time i drag a bookmark the folder closes, and its a hassle to have to open that folder, for every bookmark i want to re order
Feature request: can you guys make it so that the folder does not close, every time a bookmark is dragged and re-ordered inside a bookmarked folder
Pls, Thank you!
You can rearrange your bookmarks on brave://bookmarks/.
The devs actually did it <3 absolute GOATS.
THANK YOU!
will forever be a brave advocate.
