Bookmarks will not import.
Welcome, @Fitzcarraldo. Could you please share what version of macOS you’re using (Apple menu–>About this Mac) and what version of Brave (brave://version or, to also initiate update check, brave://help)?
I thought this had been solved, but can’t find evidence of that, now. @Mattches, do you know whether it has been? Would granting Brave full disk access do it?
In the meantime, there’s this workaround:
@Fitzcarraldo,
Please repost (or edit your original post) to reflect the template and guidelines and we’d be more than happy to assist you.
@Fitzcarraldo,
I can look into this but in the meantime, I’d recommend simply Exporting your favorites from Safari and Importing them manually:
- In Safari, go to
File --> Export Bookmarks, save these somewhere on your machine. - In Brave, go to
Menu --> Bookmarks --> Import bookmarks and settings and selectBookmarks as HTMLfile from the drop-down menu.
I will try. Thank you.
That worked. Much appreciated.
