Brave just crashed 2-3 hours ago now with 10 tabs open.
Restarted and Brave did not say ‘Sorry for the crash’
or anything like FF does.
Didn’t automatically restart the pre-opened tabs when I restarted
the browser. Also the customize & control icon (3 lines top right)
is intermittently working when I click on it. This all started 3 days ago.
I’ve been using the browser mainly with little or zero glitches.
Since the beginning of February it has been one problem
after another.
When I click on the bookmarks tab on the side of the browser
I can see a partial menu, like it only half opens or something.
If I click on it multiple times then the bookmarks appear as normal.
Same goes for the 'Customize & Control icon (top right 3 line)
in the corner of the browser.
I also tried to reset my Brave browser back to the default
setting and the circle just went around and around and
around for 15 minutes before I finally just closed the browser
down.
Any thoughts on why these anomalies are happening well
into my first month of relatively minimal problems?
I am using Windows 10 32 bit version.
Version 0.59.34 Chromium: 72.0.3626.81 (Official Build) (32-bit)
