BAT disappeared and Mobile won't link Uphold wallet that was already verified
Briefly describe your issue:
Around 2 BAT disappeared that was gathered throughot the month of December payout was a few days ago and still nothing. Also on my Android phone Brave stays on loop while trying to link my Uphold account and if I tap to verify again it crashes
Windows, Android
Yes
2 months ago
Yes
Are you using a VPN? (yes/no)
No
Yes
Yes, it does
Yes, I have
One issue, most likely, is that you have reached your device limit (4). If you have a new device, or have reset a device, that can cause issues. If that is the case, you can find help in the link below, to remove an old device. This post also has some screen shots to help if need be. Hope that helps you.
I’ll be trying that. Thank you so much
