Description of the issue: Appearance of “Data Breach in Progress” banner
How can this issue be reproduced:
Brave booted up in Incognito Tab.
Small banner appeared for 1 -2 seconds reading “Data Breach in Progress”
Consider this a legitimate warning because of previous data breach issues.
Expected result: Unknown
Brave Version( check About Brave): 1.85.117 Chromium 143.0.7499.146
Mobile Device details: Android 13 tablet with ProtonVPN, Sophos Intercept X, Avast Premium, Brave with all shields locked down.
Additional Information: Was using Brave with all shields set to highest settings. In open window, small banner appeared reading “Data Breach” or “Data Breach in Progress”. Appeared to be legitimate. Didn’t have enough time to take screen shot.
It truly honestly sounds like you visited a site that managed to coax a popup in Brave despite Shields, and you were simply looking at a fake page.
Brave, nor any Chromium fork, will ever tell you directly if a data breach is actively occurring, because it doesn’t know nor have such code to detect it.
These things can happen if you visit certain sites, as it may be a tactic the list author simply hasn’t seen yet. But without a doubt, what you were staring at is a fake popup, and since Brave opens up usually to whatever you had open, I’m going to assume it was the last page you had visited in that private tab, and simply relaunching Brave caused the page to refresh, which then pulled in this popup.
Data breach events have occurred with Brave; they are ongoing and have been reported on this forum. The page was not ”fake” as you assumed. Data entered in Brave has appeared on other websites. Brave is NOT immune from these problems.
If by “certain” you were implying this occurred on a +18 site, you are again making a false assumption. I did not indicate that this was a Brave generated warning. This has also occurred on macOS 26.3.1 device.
Your explanation actually raises a bigger concern. If this banner was a fake malicious popup as you suggest, then Brave failed to block it despite maximum shields enabled on a hardened browser in an incognito window. Repeatable events with Brave on two different highly secured platforms a coincidence? I think not.
That’s not a user problem - that’s a Brave problem. Either the banner was legitimate and your assumption was wrong, or Brave’s shields failed. Which is it?"
I did not, certain can be anything that isn’t 18+ as well, but what I stated still stands. What you saw was a FAKE popup, plain and simple. But now I am wondering why you haven’t shared what site you were on when this popup was received.
Nothing is fool proof, report the website you were on so it can be properly blocked.
Your reply sort of feels that you are indicating that, because you seemingly are believing a popup of some kind (bad actors do lie you know, it’s called social engineering).
