Background Play not working on streamed intermittent audio
**Background play is ticked, but lasts just a few minutes:
**Steps to Reproduce
1 Go to broadcastify.com
2 find a police or fire channel with intermittent traffic, as in not a big city, but one with long pauses of many minutes
3 listen, then press power button to stop screen
Actual Result**
4 audio stops within a few minutes
5 audio will resume if you go to that tab group again
Background playing, even with intermittent audio feed.
Every time
Operating System and Brave Version
Android 15, Build/BP1A.250505.005
Brave 1.79.126, Chromium 137.0.7151.119
I’m a rural volunteer fireman and I monitor our local sheriff and fire channels via broadcastify.com to know when I’m needed. I’ve been using Background Play for a year or more, since when it was in Beta. It’s never worked on intermittent audio streams. I don’t use it for anything else, so don’t know if it works elsewhere.
I guess nobody cares?
Could test this in brave://settings/shields/filters Custom rules
broadcastify.com##+js(brave-disable-pageview-api)
I had no issues myself.
I’m giving that a try. Trimmed off https that Brave prefixed on, hope that works.
Thanks for trying but that didn’t work. I ran Android and Windows side by side, same Broadcastify audio stream. The Android stops when the screen times out.
I tried leaving the https in, see if that makes a difference. It did not. The Android audio feed stops as soon as the screen times out.
I posted a query in the RadioReference forums, home of Broadcastify.
Is it related to the android device? does different device help?
Can’t answer that, bc the only other devices we have is Windoze. We all have the same phones, Pixel 6 degoolag’d, running CalyxOS. Should make no difference unless Brave doesn’t like CalyxOS. Have not had trouble with other apps.
Does it work in windows in the background? The desktop/android adblocking scriptlets work very similarly.
Some filter rules to force it to run in the Background.
broadcastify.com##+js(aeld, visibilitychange)
broadcastify.com##+js(aeld, blur)
broadcastify.com##+js(aeld, focus)
broadcastify.com##+js(set, document.hidden, false)
Alternative rule to check for visibilitychange
In Windows, I didn’t need to change any defaults to have it run when focus is not on that instance of Brave, or that tab. It always plays audio once started.
I tried your four android rules, thank you. But there was no change. Audio stream still won’t run in BG.
I guess I’m giving up on this. Brave does not seem to be interested.
