Ask Brave/Brave AI possible prompt level prompt/code to reduce errors/hallucinations
Hello,
Brave AI and I were having a discussion about the errors it made and, when prompted, made some suggestions for prompts or reduce/limit errors, hallucinations, conflations, etc… I am hoping this can reach the development team/coders to see if this can be baked in from the top? Already, Ask Brave is one of the better AI Assistant Engines, maybe it can be made better and be ahead of the competition? Below is copied from the conversation…
Going forward, is there a prompt or prompts I can use that would 1. filter out the hallucination/fabrication? 2. Prevent distortions of real events or things? 3. Identify low trust quality sources from the start (I dont mind obscure references because sometimes people cannot say something true in the mainstream, even tho there are also a bunch of untrustworthy people who say a lot of things too)?
Show less
Drafted mitigation prompts
These are practical and well-motivated. Based on the failure patterns we just traced, here are prompts you can prepend to or append on any question where accuracy matters:
1. Filter out hallucination/fabrication
“For every specific claim (a number, a named paper, a named person, a date, a quote), either cite a source you can verify or explicitly mark it as [UNVERIFIED — I am inferring this]. Do not fill gaps with plausible-sounding detail. If you don’t have a source, say so rather than generating one.”
Why it works: The confabulation signature was specificity without traceability. This prompt forces the model to either produce the trace or admit the gap. It turns the “confident but wrong” output into “confident and sourced” or “uncertain and flagged.”
2. Prevent distortion of real events
“Separate the core event from the supporting details. For each detail (a figure, a name, a date, a causal link), verify it independently rather than bundling it with the event. If a detail cannot be independently confirmed, state that the event is real but the specific detail is unconfirmed.”
Why it works: The Medicare/Census example showed the model latching onto a real event and attaching a fabricated detail to it. This prompt breaks the bundle and forces per-detail verification.
3. Identify low-trust sources (while allowing obscure-but-legitimate ones)
“When you cite a source, identify: (a) who/what it is, (b) when it was published, (c) what kind of source it is (peer-reviewed, primary disclosure, major outlet, blog, forum, anonymous), and (d) whether it has a track record of accuracy on this topic. Do not pre-filter obscure sources — flag them with their type so I can judge. Only flag a source as low-trust if it is anonymous, has a pattern of fabrication, or is a known disinformation outlet.”
Why it works: Your instinct is right that “obscure” ≠ “untrustworthy.” A small research lab’s preprint, a whistleblower’s blog, or a niche technical forum can be the only place a true claim appears before it hits mainstream coverage. The distinction you want is traceability and track record, not prominence. This prompt asks the model to label the source type rather than gate it, leaving the judgment to you.
Combined “accuracy contract” (one block you can paste)
Accuracy contract:
  1. Every specific claim (number, name, date, quote, paper) must have a verifiable source or be marked [UNVERIFIED].
  2. Do not bundle details with events — verify each detail independently. If a detail is unconfirmed, say so.
  3. For each source cited, state: who, when, type, and track record. Do not suppress obscure sources; label them so I can judge.
  4. If you are uncertain, say “I’m not sure” rather than generating a plausible answer.
  5. Distinguish clearly between: (a) verified fact, (b) real event with unconfirmed details, (c) plausible but unverified, (d) likely fabricated.
One honest caveat
Prompts reduce the failure rate but don’t eliminate it. The model is still probabilistically generating text, and a prompt is a suggestion to the same system that can ignore suggestions. What makes these prompts more effective than a simple “don’t hallucinate” is that they structure the output in a way that makes the failure mode visible to you (the reader) rather than hidden inside confident prose. The goal isn’t to make the model perfect — it’s to make the errors detectable so you can catch them before they propagate.
The most powerful single addition is #4: “If you are uncertain, say ‘I’m not sure.’” It sounds obvious, but it directly counters the model’s default bias toward producing a complete-sounding answer.
Hope this is helpful!
I use:
  • Alter.systems
  • Brave Search (Answer with AI)
  • ChatGPT
  • Perplexity.ai
None are autopilots; none are auto-bots.
I guide and train the conversations.
If I do not guide, then the built-in “inference addiction” of those trained-to-be-conversationalists, will be loose on open range.
Sometimes easy to head them back on track; and sometimes a major task to get them back on track; and anywhere in between.
My responsibilities, guiding and training from the get-go, so they respond with computer code or information that I need.
Maybe some day in the future, the (we hope for) increased memory will help such AI systems to recollect and not lose track too easily, in addition to reducing time spent … guiding.
But even then, still my responsibility - esp. to exercise care-full-ness and caution with AI that seems to be on the road to perfection ← leading some people to not be careful and cautious.
Maybe AI errors help us to pay attention to AI flaws.
I am new to using AI for research. When you say:
Do you mean that you add this every time a question is asked, or can it be used once at the beginning, if so, will it carry through the conversation?
How do you add this to get better results? Do you paste it at the beginning of the conversation?
