An easy, built-in way to report websites using Anti-adblocks
@iamb9 comidoc.net is fixed, give it 24-48hrs.
(also see my response regarding the others)
Thanks for the FIX :wink:
timesofindian.com
all contains blank Empty placeholders of ads.
Switch to Aggressive mode @Datta
Hello,
Your search engine results have become better than before. Please introduce a feature in Brave Desktop to choose different search engines in normal and private mode. Let me explain you why it is needed. I don’t like DuckDuckGo search results but I have to keep DuckDuckGo as a search engine due to the privacy extension. I have installed it as it provides a two layer security for me. If some trackers escape Brave Shield then it is blocked by DuckDuckGo extension, I myself have experienced it. Once it showed me 2 trackers blocked in spite of Brave Shield being active. If you would introduce different search engine for private tab then it would be beneficial for me as well as for others. For my accounts and all I will get 2 layer protection and for good search results I would use private window only with Brave Search as my search engine. Hope you get my point.
Thank You,
Mohak
Hey, the website “tviplayer.iol.pt” has now started blocking Brave’s ad-blocking feature: the videos across the website won’t load/be displayed unless the browser’s protection tools are disabled. (I don’t know if this is the most appropriate place to report this…). Could someone please take a look into it? Thank you very much in advance.
https://hdrezka.ag/ looks like they found a method to bypass brave/ublock Origin adblockers.
Sidebanners and similar stuff I was able to block manually by adding each element to block (on pc but not mobile brave). Can’t always block video Ads before videos PC or mobile anymore (blocking does not always work).
Aggressive mode either do nothing or brakes video player so can’t watch anything with that turned on ( time to time).
Whats broken on the site, any directions to reproduce any issues
  1. brave adblocker doesn’t block ads on https://hdrezka.ag/
    1.1 open website
    1.2 page full of adds
  2. aggressive mode on videos don’t block adds before video
    2.1 open website with aggressive mode ON
    2.2 open any movie
    2.3 press play
result
most of time you can see video ads - block doesn’t work
aggressive mode on videos don’t block adds before video or popups, side adds.
yesterday for me few times (with aggressive mode ON) nothing happened after pressing play button , just black color inside the videoplayer on the website( no adds but no video played as well). Cant reproduce the black screen of the video player today though. Now I see video adds before video in any mode .
the only way I was able to block video ads somehow is - turn option script block on but then there is no play video button whatsoever after page refreshes . Then turn off script block option -page refreshes - play button appears and now it’s skipping video ads inside player after play button pressed . After some time video ads come back . I was using this method yesterday , today ads came back. After repeating this steps - no ads again but not sure how long it will last and why it works .
all that for PC version. No effect on this website from aggressive mode ON or script block on Mobile (android) app. All side ads , popups , ads before any video played like there is no adblock working at all , on mobile.
Try enabling the 2 Russian lists in brave://adblock
But I saw no popups here; https://hdrezka.ag/films/action/70786-atomnyy-poezd-2-2002.html
awesome. Thanks. Just checked - Ru Adlist or Adguard Russian worked in blocking all ads both video and side|popups .
Btw on this website search works in English and if you click * Оригинал (+субтитры) in player - usually last one in player you can watch in english :slight_smile: ( for a lot movies TV shows but not all)
Thanks again. Worked on both PC and mobile
