AirPods microphone not working on Brave (macOS)
Description:
Hi,
I’m experiencing an issue with the AirPods microphone on Brave for macOS.
When I click the microphone icon on ChatGPT, nothing happens — my Spotify volume drops and audio quality decreases (Bluetooth HFP profile activates), but no input is detected from the AirPods microphone.
What I’ve tried:
  • Microphone permission enabled in Brave
  • AirPods selected as input device in macOS
  • Works fine in Safari and Chrome
  • Enabled flag #enable-experimental-web-platform-features
  • Tested without extensions / in private window
Device info:
  • Brave 1.83.120 (Official Build) (arm64)
  • Chromium 141.0.7390.122
Any workaround or fix available for AirPods microphone compatibility in Brave?
Thanks,
Gauthier
Hello! I’m unable to replicate the issue and the mic works successfully in ChatGPT for my Airpods.
Please double-check your mic permission settings. This link should take you directly to the ChatGPT site permissions:
brave://settings/content/siteDetails?site=https%3A%2F%2Fchatgpt.com
