Assuming that you have already created and tried a new Profile . . .
In a Brave Browser New Window, go to:
brave://extensions/
Disable and Remove all extensions.
Clear browsing data on your Mac
brave://settings/clearBrowserData
Select the Advanced tab
Set Time range to “All time”
ENABLE everything except:
- Passwords and other sign-in data
(Myself, I would NOT make that exception)
(because I would have a backup prepared.)
(In other words, be prepared.)
Click on the “Clear data” button
On your Mac, locate the Caches folder:
/Users/your_shortname/Library/Caches/
and move the “com.brave.Browser” folder to the Trash
`brave://net-internals/#dns
Click on Clear host cache
Next, same window, select “Sockets” on the left.
Click Close idle sockets
Click Flush socket pools
Quit everything and Restart your Mac
Open a Terminal.app window, and enter:
open -a "Brave Browser.app" -n --args --disable-gpu --enable-leak-detection --crash-on-failure --incognito
That command will start Brave Browser with Hardware Acceleration DISABLED, and using a New Private Window.
In the Brave Browser New Private Window, go to a very, very plain, simple website:
https://test.nextdns.io/
. . . and wait at least 10 seconds.
Hopefully, the browser got there, quickly.
Quit all applications.
Flush the MacOS DNS cache:
In a Terminal.app window, enter:
sudo killall -HUP mDNSResponder
Quit all applications and Restart your Mac.
Scroll down that settings page, to Sites that can always use cookies
Click the Add button
Enter [*.]google.com as the site . . . but do not Enable the following:
- Current Private session only
- Including third-party cookies on this site
Repeat those steps for:
[*.]firebaseapp.com
[*.]googleapis.com
[*.]googleusercontent.com
[*.]gstatic.com
[*.]youtube.com
Next, go to:
brave://settings/content/javascript
Scroll down that javascript settings page to Allowed to use javascript
[*.]firebaseapp.com
[*.]googleapis.com
[*.]gstatic.com
[*.]youtube.com
