When I enter my recovery phrase or import file, it sometimes says imported, and sometimes says nothing, but it does not populate with over $100 of rewards.
- Setup rewards in Beta Build
- Import my key
- See result
It is supposed to populate with my rewards but instead nothing shows up
Version 1.13.54 Chromium: 84.0.4147.105 (Official Build) beta (64-bit)
If it helps, I never setup Uphold, I was using for tipping. I would like the BAT back if possible.
