Tab Tiling (Vivaldi/Arc): View two, three, or four tabs simultaneously in a single window (split-screen) without opening separate OS windows.
Two-Level Tab Stacking (Vivaldi): Group tabs into a “stack” where clicking the stack opens a second row of tabs underneath, keeping the main bar clean.
“Little Arc” (Arc): A lightweight, “peek” window that opens when you click a link in another app (like Slack), allowing you to view it quickly without shifting your entire browser context.
Auto-Discard/Sleeping Tabs (Edge): An aggressive, native UI for putting background tabs to sleep to save RAM, with a clear visual indicator (faded icons).
Tab Preview/Glance (Zen/Edge): Hover over a tab to see a live, miniature view of the page’s current state instead of just a static thumbnail.
Vertical Tab Auto-Hide (Edge/Zen): A vertical tab bar that collapses into thin icons when not in use and expands only when hovered over.
