"Adblocker recognized" on radio.net
Description of the issue: Error pop-up when trying to stream a radio.
Exact URL of the website in question: https://www.radio.net/ and choose any radio.
Did the issue present with default Shields settings? yes
Does the site function as expected when Shields are turned off? yes
Does the ad appear when using a Private window as well? yes
What OS are you using when you see the ad? Windows 11
Brave version (check About Brave): Brave 1.91.171 (Official Build) (arm64)
Chromium: 149.0.7827.103
Until the filter list is adjusted, two checks are worth doing: open brave://components, update Brave Ad Block Updater, then reload the page; also try Shields = Aggressive just for radio.net. If it still happens with current lists, the exact station URL would help support more than the homepage, because the player/adblock script can vary by stream.
If it still appears after updating the adblock component, I’d also use Shields → Report a broken site while you are on the exact station page. radio.net can serve different player scripts depending on the station and region, so the homepage alone may not give the filter maintainers enough to reproduce it. In the meantime, allowing that site only when you need to listen is safer than turning Shields down globally.
Thank you for your reply. Yes, I have also reported it.
Looking into it, will update thread.
