Adblocker not working for "click anywhere" ads
https://aniwaves.ru/ is the website I am having trouble with.
When I click anywhere on the screen it takes me to a porn website.
Not only is this just annoying, but I don’t like being flashed with porn while I’m trying to chill and watch my show.
Moved your thread into the Brave Browser > Ad-Blocking category.
cc @fanboynz to take a look here.
In the meantime, make sure you’re browser is fully up to date and, additionally, you can check and ensure all ad-block filter lists are up to date by opening the browser, going to Settings > Brave Shields & Privacy > Content filtering and tapping the Update lists button here.
Same for me, everything is up-to-date, filter is also updated, even use aggresive block, but still has popup ads (anywhere click/touch) that redirect to another android app or website. My solution is to use aloha browser for android, and use ublock origin extensions on PC.
Update the lists and try again? They update the servers often
bobmovies.org is also doing this. if I click anywhere on the site it redirects me several times to malicious websites with trackers and ads set to aggressive and pop ups and redirects blocked in settings. I’ve also updated filters manually several times today and nothing changed
shields should block this by default
Brave 1.97.59, Chromium 155.0.8059.85 on android
it was fixed for a day and the redirects on bobmovies.org are back again and brave does nothing to stop this from happening. I tap anywhere on the site and it opens a new tab and redirects several times to gambling or ai porn websites.
please do whatever you can to prevent sites from being able to do this
