Ad block not working anymore on youtube
I will remember that and dig more next time.
Looks like we have a fix in for this:
https://old.reddit.com/r/brave_browser/comments/1hinfh3/youtube_now_suddenly_blocks_me_for_using_brave/m31kcmw/
In brave://components force an update of Brave Ad Block Updater too Version: 1.0.9653 or better
Then refresh Youtube.com tabs (important). Let me know if it helps
Ensure no other adblocker extension is enabled.
It worked. I like Brave for its speed and also plays vids in 1080 and even 1440 something when Chrome was only doing 720.
tysm it works!!!
Im so lame I cant even figure out how to log out of YOUTUBE! LOL
lol. Honestly, you’ll get logged out when you clear cookies so it may not matter but doing it first and kind of leaving makes sure you’re not accidentally triggering again. But click on your profile picture or whatever in the corner to pull up the option to log out. Such as:
thanks! for some reason its working again so they must have gotten my premium sub.
Merry Christmas and thanks for your help!
Youtube may also be somehow factoring in the Brave agent string into their adblock detection.
If I change my agent to firefox (windows) using the developer tools (network tab, ā€œmore network conditionsā€ button) then it also works around the issue.
To everyone reporting, was fixed
Affected us and uBO. https://x.com/fanboynz/status/1870226608306692191
In brave://components force an update of Brave Ad Block Updater too Version: 1.0.9653 or better Then refresh youtube tabs (important). Let me know if it helps. Ensure no other adblock extension is being used also.
I did the component thing my videos are working now but there’s no sound
hehe, any idea what to do
It works! Tks so much
That’s it, the update 1.0.9653 solved the problem. Wasn’t my cookies or extensions as I suspected.
Dunno why Youtube is so set on making me watch ads. First rule… if I see an advertisement for something, I’ll never buy it. :stuck_out_tongue:
This worked wonders! Thanks!
Same problem, ā€œAd blockers violate YouTube’s Terms of Serviceā€
this isn’t working anymore after signing in again
