I just cannot open the brave://rewards/ page. A white empty window always pops up and slows down the browser and cannot be clicked away or removed or anything.
Everytime I try to access brave://rewards/ from the settings menu or directly.
Everytime
Version 0.64.77 Chromium: 74.0.3729.169 (Offizieller Build) (64-Bit)
on Mac OS X 10.10.5
I’ve also tried deleting browser history and settings as well as re-installing but to no avail …
I updated to Version 0.65.118 Chromium: 75.0.3770.80 (Offizieller Build) (64-Bit) but the issue is still the same …
@shan_noodles,
Can you try disabling Hardware Acceleration and see if that resolves the issue? Do you have any extensions installed?
Are other internal pages displaying correctly? Like brave://sync for example?
Aah, disabling Hardware Acceleration makes it work (the browser also got even faster all in all)!
I had no extensions installed and all other sites like brave://sync (& all other settings pages) worked without problems.
Thanks!
@shan_noodles,
Excellent! Glad to hear this worked for you.
Please don’t hesitate to reach out if you have any further questions or concerns.
