A couple of issues
The translator on the Dev works really well but I’ve got a couple of issues.
Firstly, my Media Hint extension always comes up ‘off’ and I cannot access BBC or any of my other UK TV sites. I go into ‘manage extensions’ but there is nothing I can do. However, it works perfectly on the non-Dev.
Secondly, in Tor mode, would it be possible to have a UK IP address, then my first issue would be solved?
@murdowski,
What steps have you taken to get the Media Hint extension to work? On my end, I was able to (surprisingly) get the extension to work without issue on first install. Went to bbc.co.uk to view and stream content – Media Hint shows as “on” the whole time:
I believe that we have this functionality planned for the future but it’s not available at this time. A VPN would allow you to do this, however.
I’ve just tried it again and it does not work for me. I tried uninstalling and re-installing and nothing!
@murdowski,
To confirm, this only occurs on Dev build, correct? The Release version of the browser works fine with Media Hint?
