still not fix
yep, I encountered the same issue. it first started about 2 hours ago.
I have the same problem too.
problem is still going
Hi there everyone! I’m on the publishers team and am currently investigating this issue.
The service already works for me. Problem solved. Thanks.
It worked fine. Thank you sir!
They started to fix! Come and check, I have lost an error
I think that this error for me comes from the different ip changes, but it is a problem from their site. Thanks for the fix
Do you change ip addresses? Are you probably a traveler?
I didn’t change the ip. But now it works.
The fix was deployed 15 minutes ago - glad to hear it’s working now.
