When I tried to run “2v2.io” a browser game on Brave iOS Browser.It shows the loading screen of the game but it doesn’t get completed I.e it stops loading but when I push or pull or scroll the loading page of the game;The game UI is already opened in the background but I can’t access it because the loading screen freezes.So I hope you will look after this issue and resolve it as soon as possible.
Hello - Thank you for reporting. I was able to replicate the issue on iOS and have sent to the team for review. Disabling Shields does resolve it in the short-term.
Please Brave Team.Help me out to get out of this problem.I have been waiting from so many days yet the work isn’t get completed.Please do quick.Please
This should have already been resovled by now – can you ensure you’re using the latest browser build and that the Brave ad-block component on the (brave://components) page is fully up to date?
This is a screenshot displaying particular webpage of Brave Components.You check it and tell me if it’s up to date or not because I am not understanding it.:
Sorry – I missed the fact that you were using iOS for this.
Can you please visit 2v2.io, open the Shields panel and toggle Shields “on”, then set the Ads and trackers option to Aggressive and then see if the site works after this?
Thanks @Mattches very much!!! 2v2.io works with Trackers and Ad Blocking set to Agressive.Thank You Very Much!!!I was asking Solution to this issue from long time but it doesn’t get solved.Thanks! @Mattches I request that please make this Brave Community Members active so that problem get solved faster.
